Location of wire or wires for passing lamps?
Hi. I'm putting my passing lamps back on.
The previous owner removed them so I'm not sure exactly how it was left -- tied up or whatever, but what would I be looking for? One or two wires coming out from the (AUX?) switch or elsewhere behind the headlight? (I assume one, because the inside body of the lamps appears to have the ground wire.)
I'm not looking forward to re-aiming the lamps once re-wired, because I don't have that special slotted socket...
Thanks for any insight on the wiring.
BTW, thanks to this forum I was also able to find 35W replacement bulbs, up from the stock 27W so I'm looking forward to a safe and reasonable output bump. GE 898. Cheers.
It's fed by a 2-position connector with 2 GY/BLK leads that is fed from the toggle switch.
Received 8,248 Likes
I went to autozone/o'rielleys and bought the cheapest 9/16 six point deep socket i could find. then i took my small 4" grinder and ground off one of the slots along the side of the socket. this is now my special slotted socket for adjusting the driving lights. this took all of 10 minutes to grind out and smooth the socket.
Lamps work great. I put some 35W bulbs in to replace the 27W bulbs.
I ended up zip-tieing the passing lamp wires to the housing for the turn signal wires for the first half of their run. Then the passing lamp wires run by themselves inside the headlight facile until they get to the 2 pin socket. Seemed safe.
katanaplanet
11-04-2014 07:41 AM
bobbyw47
04-27-2011 12:38 PM
