Cruise Control operation?
Old 09-01-2014, 12:38 PM
Ezridr60's Avatar
Ezridr60
Ezridr60 is offline
Default Cruise Control operation?
Have this new to me 2007 Ultra. Also my first experience with cruise control on a motorcycle. Just want to know if what I am experiencing at engagement is normal or do I need to have it adjusted. If I release the throttle as soon as I actuate the set switch there is an immediate slack off of the throttle and then it comes back to the set position. Results in a somewhat uneven application of the cruise control, however if I hold the throttle at the set position for a few seconds and then release it there is no jerking. I assume by holding the throttle in the set position it allows the stepper motor to take up slack in the cruise cable. So the question is, is this the way it is supposed to work? Is this normal or am I being too fussy?
Old 09-02-2014, 03:41 PM
August's Avatar
August
August is offline
I'm on my fourth Harley that's had cruise control. All of them have operated exactly as you describe. I've learned to be smooth in my operation of the cruise control. Like everything else on a Harley -- smoother is better.
Old 09-02-2014, 06:51 PM
Ezridr60's Avatar
Ezridr60
Ezridr60 is offline
Thanks for the answer. I was just thinking the engagement should be somewhat less "jerky" without necessary input from the rider to make the engagement a smooth transition.
Mars47
05-15-2017 08:55 PM
eqcons
2014-2023 Touring Models
66
06-02-2014 06:32 PM
GPHDXLC
06-24-2013 12:51 PM
powaypete
01-23-2010 03:59 PM
JCleary
10-09-2009 05:37 AM
Quick Reply: Cruise Control operation?
