14' SG Error Codes: P-2122 and P-2138
2014 Street Glide
5,000 Miles
My mechanic has re-wired everything in my 14in bars. Throttle By Wire and Sensors all replaced. Wiring for everything is perfect. No pinches. Zip ties. Everything has been done perfect. The check engine light is not on but we are still getting the error codes:
P-2122
P-2138
Neither of the codes can be cleared. Any help on this issue would be greatly appreciated. Thanks in advance.
5,000 Miles
P-2122
P-2138
2014 Street Glide
5,000 Miles
P-2122-TGS1 Low/open
P-2138-Open/short to grd/short to voltage TGS1 or TGS2 or TCA malfunction
5,000 Miles
Better open it up again and look at it carefully.
Problem Solved
As you all know, these codes are all over every forum. The codes are what they are and mean what they mean yet no one seems to be able to solve the problem. Here's what I know, my problem has been solved. Again, my mechanic did re-wire everything and replaced the TBW with the Screamin Eagle TBW. And after all that, still was not able to clear the codes. The problem, ultimately after the initial problem was solved, remained in clearing thes code and avoiding the dreaded "limp mode" again or code P-1510. And after numerous phone calls to both dealers and friends in the business, my mechanic explained to me that the answer to that final problem was found deep within my ECM. And if that doesn't help anyone who finds this post I give you one of the smartest and most talented Harley mechanics on the planet.
Brian
BPA Inc.
Calhoun, GA.
706-629-9776
This man is the real deal with a shop to back up his talented reputation. From a complete dyno booth and the talent to produce "real" results to at least 4 motorcycle lifts. All well organized, clean, and 100% legit. Just glad I found him when I did. Has my '14 103 running extremely well. That's all. Good luck.
Brian
BPA Inc.
Calhoun, GA.
706-629-9776
Harley Davidson Street Glide FLHXS 2018
After change the handlebar i had the problem check engine light was on. i get the error codes P1510; P2122; P2130. It was impossible to clear the codes.
Throttle By Wire and Sensors is the problem. by the connector under the front cover it was one pin slide back. After i see this problem and removed the pin back in the connector the problem was gone.
then i cleared the codes in the ECM.
The test drive was successful and the cruise control worked fine.
Eagle240
04-24-2022 06:41 PM
