07 flh high idle with 4 codes
This started about 3-4 weeks ago first when stopping eng died turn off restarted had little more idle problems about 900-1000 stubble few times from then on ran ok but higher than normal idle last weekend started going from 1500 cold/warm up to almost 2000 hot codes was p0152 p0501 p0505 p1358 ck for vac leaks iac operation sprayed cleaner through iac port ck plugs and wires all ok cleared codes started and after a few lite on again p0505 stored I'm lost now don't want to have put bike shop for weeks hope someone can help
Thanks bob
Thanks bob
jrsuperfrog
07-03-2014 08:58 AM
