Head Work or Big Bore
Looking for some input/advice. Stock 99 Softail Custom. 80" 1340. S&S Carb.
Looking to do some engine work over the winter:
-Port and polish the heads & install a cam, keeping the stock displacement
-Big Bore kit (88"?) & install a cam
Any thoughts on either route? Other ideas? Pros & Cons?
Thanks in advanced.
Thanks in advanced.
Received 14,165 Likes
Andrews EV-3, or Wood 6 and our Stage I Heads would put a big smile on you face.
Dyna 2000i ignition would be a good addition as well.
If pulling it down yourself, you'd be well withing you budget.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
This is what I done to my 95 Heritage.
Andrews EV-13 cam $119.95
Dynojet Thunderslide with Jet Kit 8708 $128.42
Crane Cams Time Saver Adjustable Push Rods 4-0030 $126.72
Dynatek 1009002 8 pin to 7 pin adapter $25.95
Dynatek 2000P DD2000-HD2EP ignition module $145
Crane Cams big axle lifters 3-2050. set of four for $189.95
Crane Cams cam bearing 7-0400 $15.51
Cometic Cam Gasket Service Kit C9624F $19.04
Cometic EST Top End Gasket Kit w/.030" Head $87.39
Screaming Eagle Air Cleaner Kit (Carbureted Evo) 295433-99B $127.96
New set of stock rings
Milled Heads .025"
It now runs remarkably smooth and produces good torque right from idle
Milled Heads .025"
???? leakers? not when their built right.ide have to agree with scott on this one,a WOODS 6 with matched compression would be my choice over the Andrews cams mentioned
Yep, Rosa's tuned off one of our's a while back with the same/same set up that posted just a tick more.
That one had a E carb that was Thunderjetted.
If wanting to step into the deeper end of the pool, then a Wood 8 @ 10.8 cr, with our Stage II Heads will show 95/95, and have one(of several many we've built) in Lyon's Falls, NY, that followed our recipe to the letter, and we tuned it off at 99 hp and 98 ft/lbs, sae.
1990 FXR with 3.37 gearing.
50 plus mpg, and he drives it everwhere.
Scott
Scott
