1340 Evo Engine Rebuild
Have question about Cam! I surfaced .040 off my heads, so I wanted to make for sure that the pistons are a stock compression ratio in .010 over. Using stock H/D gaskets. I want to use Andrews Cam with 600 lift. Looking into ordering Wiseco Pistons (K Kit) Does anyone know if any issues with valve clearance? Worried about Spring retainers hitting valve seal and pistons. How much more of a Cam can I use or the Andrews Cam work with the Wiseco?
OE springs can handle up to .510" lift.
The Wiseco piston valve reliefs are machined very deep to handle large TDC lift cams, as well as larger valves.
Happy to help.
Scott
Happy to help.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
