'76 IronHead hard starting
Just picked up this '76 IronHead. The guy I got it from said he wasn't mechanically inclined. He did have a mechanic go thru the carb. And had replaced the plugs. Never did anything to the points. He said it might need Timing adjustment. After quite a few tries and near starts he got it running. I couldn't even get a near start. Got it home and tried and still can't even get a near start. I've got to get a manual on order and some new points for it. In the meantime I was wondering if any one here could give me some tips on starting. The guy told to crank it he would choke it for one kick. Then no choke. Also he said not to give it any gas. I didn't want to put a starter on it but I am now rethinking that one. I had a '65 650 BSA that I built when I was kid. That's the biggest engine I've ever kicked off. Since then it's mostly been push a button.
The guy I got it from was about my size. I'm 5'11" 190#s if that make a difference.
Go thru a pushrod adj., points adj., timing adj. as per the service manual.
Check the flyweights as well.
If you have fuel, compression, and spark, it should just like turning a light switch on.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Received 47,790 Likes
Best way to attend to the flyweights is to replace them with an ignition rotor, and a Dyna 2000i, or DTT.
Once that is all set, you'll never need to get back in there for maintainence again, but then again, after a set of points settles in and the flyweights are in good working order and lubed occasionaly, they'll give good servire.
Scott
Scott
