SE Big Bore Stage 1 Kit
You failed to mention model year, so I assume pre-07.
First thing; let's get the lingo straight. Stage I is exhaust and air filter; Stage II is big bore.
Check compression. 95" should show about 180psi; 88" will show about 165psi.
Or, pull cam chest cover; typical dealer install Big Bore kits will include the SE203 cam set and you can read the cam nose to confirm.
Run a check on the VIN; if dealer installed, it should show up.
I apologize for not specifying the model and year. It's a 2004 Softail Standard FXSTi. I was told the same regarding the Stage I kit from my father-in-law but when I Google the part number from the parts quote it shows up as SE Big Bore Stage I Kit. The part number is 29774-02B. I don't believe they sell this kit anymore.
I will take your advice and call the dealership that installed the kit and hopefully they can help me.
Thanks for the responses.
Paul
Paul
Paul
Paul
