evo base and can gaskets leaking
Old 10-17-2014, 07:18 PM
Matt91's Avatar
Matt91
Matt91 is offline
Default evo base and can gaskets leaking
Hey everyone, I'm new to the forum so bare with me.
I have a 96 softail custom evo. It has started leaking oil for the base gasket and around the cam cover since the cam swap, HD did the work. They fixed it once and now its starting all again. Should I try using another brand of gasket or just use OEM again? Any help from the ole evo guys would be appreciated .
Old 10-19-2014, 11:04 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Matt, welcome to HDF from the UK. For future reference we have an Evo section, where you can meet fellow owners. I've owned my Evo since new in 1990 and suffered both problems in the distant past, but used aftermarket gaskets with success. So that is my suggestion, but call over to the Evo section, where you can get more specific advice, like brands.
Old 10-19-2014, 10:15 PM
dfwhockey17's Avatar
dfwhockey17
dfwhockey17 is offline
I have had this kicking around my shop for a while now, PM me and you can have it for $25 shipped.....
Old 10-20-2014, 07:22 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
We've seen the Evo base gaskets leak for years here.
When we have one come in that is probelmatic, we machine the cylinder bases(skim cut)to establish a true, flat surface, and also to insure perpendicularity of the cylinder base to the bore.
Leak-free at that point.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 10-23-2014, 10:58 PM
Matt91's Avatar
Matt91
Matt91 is offline
Thanks guys for all the great info. A base gasket change, Is this a job I can do myself or is it back to HD?
Old 10-24-2014, 05:33 AM
Hillsidecycle.com
Sponsor
Service manual, torque wrench, ring compressor, etc. is needed.
Note;
If this is going to be the 3rd known set of gaskets, machine the cylinder bases as I have already made mention of.
They will not leak anymore.
Scott
Old 10-25-2014, 08:50 AM
grbrown's Avatar
grbrown
grbrown is offline
Wink
It is doable, with a few tools, see also Scott's reply. A factory service manual should be your first purchase, available from your local friendly dealer. You'll get your money back several times over on this job alone.
It is well worth heeding Scott's advice about the base of your cylinders. I had leaking gaskets on my Evo, owned from new and a known problem back then, but they have been fine ever since.
Old 10-27-2014, 07:54 PM
PSYCLE's Avatar
PSYCLE
PSYCLE is offline
^ this fixed my 97 RK 25k miles back and still no leaks at 66k miles and I'm not a mild type of rider. Well worth $25.
Old 10-30-2014, 11:16 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,810 Likes on 3,315 Posts
Default measure twice cut once
It would only make sense to have the jugs looked at, at the least, if you already have it apart. Kinda makes sense it was leaking in the first place....
ShadowforNow
EVO
16
05-13-2019 08:52 AM
kaiser343
Engine Mechanical Topics
09-25-2013 03:52 PM
fxesuperglide77
07-06-2009 03:40 PM
tomtwix
Exhaust System Topics
10-19-2008 09:12 PM
bigstevex4
06-04-2008 03:11 PM
Quick Reply: evo base and can gaskets leaking
