Opening cam chest question
Old 11-20-2014, 12:15 AM
txphatboy's Avatar
txphatboy
txphatboy is offline
Default Opening cam chest question
I currently have gear cams with a Wood 4 degree advance gear. I want to remove the 4 degree advance and run the cams straight up. Do I have to go thru the whole process of removing pushrods to remove the large cam gear, or can I just open the cam cover, remove the large gear bolt, and reposition the large gear? I may go ahead and remove pushrods, pull cam plate and install new o-ring on oil pump suction while in the cam chest, but wanted to know if the other is an option. Thanks for any help.
Old 11-20-2014, 09:54 AM
djl's Avatar
djl
djl is offline
Received 2,030 Likes on 1,498 Posts
You should be able to change the rear cam gear with the cam plate in place.
Old 11-20-2014, 08:23 PM
txphatboy's Avatar
txphatboy
Thanks - is there anything special that would need to be done prior to removing the gear, such as rotating the engine so pistons are in a certain position?
Old 11-21-2014, 10:01 AM
djl's Avatar
djl
djl is offline
Nothing special; however, I would rotate the crank until the two timing marks on the rear cam gear and the pinion gear are aligned as a reference point.
txphatboy
12-26-2014 06:33 PM
BungoBill
EVO
50
11-18-2013 02:04 PM
terrapin88
EVO
04-22-2013 05:52 PM
Keener
Engine Mechanical Topics
04-22-2009 09:07 PM
Wyo_Wide_Glide
Exhaust System Topics
12-08-2007 01:35 AM
Quick Reply: Opening cam chest question
