Cam???
Old 01-19-2015, 02:00 PM
Chanse's Avatar
Chanse
Chanse is offline
Default Cam???
Which is better, S&S 585 cam OR EV-27 cam
Old 01-19-2015, 03:22 PM
Next In Line's Avatar
Next In Line
Next In Line is offline
Depends on the rest of the motor.
Old 01-20-2015, 09:31 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
There's no comparison! The EV27 is designed for stock or near stock engines, with stock lift. The 585 cam gives .585" lift and is intended for larger motors. I have an S&S V107T engine which came with a 585, which is also used in the touring version of the S&S TC124" crate engine.
Why do you ask?!
Old 01-20-2015, 10:31 AM
Chanse's Avatar
Chanse
Chanse is offline
I was told it was good for more torque
Old 01-20-2015, 10:34 AM
Chanse's Avatar
Chanse
Chanse is offline
And what about Woods eight camp versus EV 27th and
Old 01-20-2015, 10:35 AM
Chanse's Avatar
Chanse
Chanse is offline
And what about Woods 8 cam versus EV 27 cam
grbrown's Avatar
grbrown
grbrown is offline
Mine gives me excellent torque, I agree. However you haven't told us what you are thinking of using it in! Tell us more of what you are planning to do.
Old 01-20-2015, 11:23 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,784 Likes on 3,300 Posts
Default no comparison...........
You cannot compare the 2 cams side by side. The EV27 is a drop in cam (no engine modification necessary) however it can provide decent torque for a stock motor. The W8 Requires 10.8 : 1 static cr. And springs in the head for a .600" lift specification also gonna need a good pipe and a/ c. And a good tuner. If you're not planning any other work than a cam just put in a woods W6 w/ adjustable pushrods. You won't regret it. Plus you already received multiple replies from some of the best builders around when you posted in the EVO section. You need chose your riding style. What do you want?
Old 01-20-2015, 02:08 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
A Wood 8 will generate more torque coming up to peak over an S&S .585.
An EV-27 is not in the same zip code as either of the above.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 01-22-2015, 08:21 AM
Chanse's Avatar
Chanse
Chanse is offline
Well I was thinking if I ported and polished my heads, I would need more than a EV-27 cam. And maybe use a woods 8 cam. Am I right?
Quick Reply: Cam???
