S&S 107 with 570 cam
After setting up my original plan for a 103 with 254e cams for my 96 Street Bob, I am not convinced about the possible numbers I will get. In other words, I want the most bang for the buck bore upgrade. So I found an indy who dragraces Harleys and can intstall the S&S 107 kit with 570 easy start cams for the same price the dealer does the 103 with SE 254E cams. Not planning on headwork (I know this is leaving a lot on the table), but looking for a reliable build. Has S&S worked out the oil problems some had with their 106 kits?
Can't find much sound clips for the 570 cam, but I want a nasty sounding bike.
Hope this cam with more cubes and added compression will give me that.
Bore your OEM cylinders and have a set of aftermarket pistons fitted; JE, CP or Wiseco. Before ordering pistons, contact the manufacturer and get the dome volume so you can run the CCP and corrected CP calcs for the 570 cam. Use a .030" head gasket, set squish between .030"-.035" and set CCP about 190. The 570 is a solid cam but there are others like the 585, 625 or Tman 590, 600SM to name a couple.
We are currently building, 3, 107"ers with that .570 along with cylinder head work.
Long-proven good combination here.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
S&S 585 with 1.725 rockers on intake side giving total lift of 615/585 with good head work and compression set @ 10.8-11.1 and a new 55mm throttle body and tuned your dyna will RIP!!!
jmd897 (02-23-2017)
