What to do to get my 2007 road king 96" to get up and go!!
That tech must've never installed a set of Andrews 48's or a set of Wood 222's then.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
One of the lead techs said that there was no point in doing cams in my 07 road king. Also said that with the 96, true duals are a waste and I could get more power with a decent set of slip ons. Wouldn't true duals be better with a tune than the stock y pipe and how would cams not help? I see why it wouldn't help without anything controling the afr but with a good tune, cams and true duals how would that not be better than slip ons and a tune? Or am I completely missing something here?
Also, what is recommended for tuning as far as a handheld flash tuner, piggyback etc.
I installed the woods 555 cams and and a Dragos 2 into 1. It ran good. Last year my trans main bearing went out so while I had it tore down I put on the 30 tooth front pulley along with the 68 tooth rear. All I can say is wow. It seriously made that big of a difference. I don't have my dyno chart but it was 90 hp and 99 ft lb. when running 70 mph it runs at 2800 rpm. Last summer on my way to work I was following a semi and two cars on two lane highway. The semi was going about 50. I passed all of them at once downshifted once and by the time I got by the semi I was going 95. The thing is it doesn't feel like it ever stops pulling.
I also have an 07 with the 96 inch motor. Based on input from Scott at Hillside, I went with the Andrews 48's.(good for stock heads/compression) I also have a V&H 2 into 1 Pro Pipe, high flow breather, and Power Commander V (PCV) I had it dyno tuned by Dr. Dyno in Daytona. I am making close to 90 hp and 100 torque. No gear change. It runs like a scalded dog. Riding is soooo much more fun now! I did all my own work, so cost was very low.
x2tpd
Motorcycles For Sale
07-27-2016 11:21 AM
easyrider026
10-25-2007 05:56 PM
