88" to 95" build - how does this look
Old 02-03-2015, 01:50 PM
JustDennis's Avatar
JustDennis
JustDennis is offline
Default 88" to 95" build - how does this look
I have a bike that I recently acquired that has a 88" TC that was upgraded to a 95". I have never done a big bore upgrade myself but have been researching the components used on the forums and it looks like quality parts were used. I'm not sure how well they work together or if I should look to change any of it. Thought I would post the information here and solicit input from the experts!
The bike is a 2001 Heritage, carb, stock headpipes with Cycle Shack slipons, and SE AC. Bike had 16K on original 88" and now has another 16K on this build.
The following parts were used in the 95" Big Bore upgrade:
  • Feuling 7000 Oil Pump High Volume
  • Andrews 37G Gear Drive Cam
  • Andrews 4 Gear set for Gear Driven cams
  • S&S Cycle Gear Drive Cam Installation Kit
  • Feuling Valve Lifters, Tappets
  • Feuling 8000 Cam Plate 99-06 Twin Cam Gear Drive
  • Feuling HP+ and Race Series Adjustable Pushrods
  • Twin Tec TC88 Twin Cam Ignition
  • Port and Polish Valve Job
  • Twin Tec Twin-Cam Coil
  • Harley Softail Vertical Mount Oil Cooler
  • SE Plug Wire Kit, Black
  • Cometic Top End Gasket Kit
Bike runs well overall. It does kick back sometimes on cold starts. How does this build look? Would the compression be OK for the cam installed? I always see cautions about the tensioners but this has been taken care of on this bike with the gear driven cams. Anything else I should check?
All input appreciated as this is new territory to me.
Old 02-03-2015, 02:04 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,810 Likes on 3,315 Posts
Default it's a big improvement.
Without knowing the compression it's hard to tell. Although that cam was designed for basically a stock 88. 9-9.5:1, Don't know what the piston deck hieght is or the squish or even the head gasket thickness as well as your combustion chamber sizes which are all used to calculate your compression. Obviously with everything that was done I would think it's within the proper parameters. You can do a cold compression test and if both cylinders are equal and around 165-170 it should keep you in the ball park..I would think that build would yield 80-85 hp. Pretty good reliable build....
Old 02-03-2015, 02:39 PM
djl's Avatar
djl
djl is offline
Received 2,031 Likes on 1,499 Posts
A compression test will tell more. A 95", 37G cams and ported heads should make 100+TQ and mid 90s HP with a good power band.
Old 02-03-2015, 03:15 PM
IHBOB79's Avatar
IHBOB79
IHBOB79 is offline
6th Gear
Im looking to do something very similar with 98" kit and 10.5 comp pistons. Hoping that the stock size combustion chambers and head gaskets will actually give that much compression on an 04 fatboy. Will do some checking though.
Cascade
Engine Mechanical Topics
29
04-21-2022 02:40 PM
jurgie
Exhaust System Topics
02-17-2011 10:21 AM
kwag245
10-31-2010 07:03 PM
jackinthebox
09-10-2010 09:13 PM
customsoftail200
11-25-2009 01:31 AM
Quick Reply: 88" to 95" build - how does this look
