S&S 570 Cams
In my quest to figure which cams to go with when I do. I've talked to 2 Harley shops and 3 independent shops in what they think. One HD shop says go with 204's, the other HD says Woods 777. Two of the three independent shop's recommended the S&S 570, the third just said we'll do whatever you want.
Actually I wished I lived closer to Kirby or Scott, I'd just pull up, unload the bike off the trailer. Just say Hook me up right and call me she's done. LOL
We were more focused on other cams then, and came to the stark realization that we can make almost any cam perform to it's true potential, surrounded with the proper components/heads.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
you've got steve from GMR in texas someplace,he can hook you up
That is the real trick, knowing what works in a given combo. I keep looking at cams for TC's and I keep comparing them to my favorite shovel and Evo cams, the Andrews AB and S&S 561, trying to remember how they performed. Then again I didn't have this many cubes to play with........
SnS 570s will make good midrange peak tq and hp for the intake duration they have.. Due to the long exhaust duration, TQ can be pretty bad on the 2000 to 2500 range on builds with high flowing exhaust ports and exhaust systems.. The throttle will feel sluggish then change behavior as 2500-3000 is crossed and start pulling hard when using partial throttle.. If this sounds like it it might bother you, go for a cam with about the same intake duration with less exhaust duration. 570s seem to work better if there is an anti reversion step in the exhaust port and / or smaller exhaust valves like what SnS uses in their heads..
nosillyname
Exhaust System Topics
20
12-13-2010 08:16 PM
