Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Might be an intake leak. Start it up and spray some WD40 around the area where the intake manifold mates up to the heads on both sides and see if rpm changes or if the engine stumbles.
Might be a leaky head gasket. Do a compression test.
