Petcock panic
Old 03-13-2015, 10:03 PM
tianhD's Avatar
tianhD
tianhD is offline
Stage I
Default Petcock panic
i have a 2001 fatboy. On the way home from work I smelled gas. I then noticed that the fuel petcock was leaking(or something around it) all petcocks online don't have a vacuum hose (mine does) is there a replacement that has a port for a vacuum hose or should I just bypass it. If bypass, how do I do that??
Old 03-14-2015, 06:25 AM
Cobra1's Avatar
Cobra1
Cobra1 is offline
Received 1,289 Likes on 523 Posts
Just cap the fitting on the carb and replace the petcock. Your auto parts store sells the necessary caps. The ones without the vacuum flow better anyway.
Old 08-31-2016, 03:06 AM
ERICBLAIR2's Avatar
ERICBLAIR2
ERICBLAIR2 is offline
3rd Gear
Default I did andmore horses in the barn and cleaner engine.
The trick is: plug any thing that air goes though except the throttle slide and manifolds. Then it's: Guess, jet ,guess and they time. She will "probably " need a little less since your not trying to burn crankcase smoke, oil and moisture, just air and gas?
Add a good inline filter or two to moderate the fuel flow, sloshing pressure, a ON OFF RESERVE maybe PRI petcock with anything bigger than 0.25 ID lines may be more than the ,"vacuum" float needle pin/valve can swallow. bypass it if you can; stretch the doing or find a stronger one and you'll be amazed how strong your tractor motor can be!
No full throttle break the sound barrier launches, without consistent plug readings, unless you have dual EGT sensors and manifold flow gages?
Mine was scary fast til I got hurt in my cage by a NAFTA truck driver.
Hope she will like pure air and fuel (no ethanol~separate it first and use it in your Zippo, if you can still afford tobacco, or Coleman stove or lantern they were made to drink that stuff since you can't drink it?)
Or
Take the cure but a pin hole or a cracked hose will suddenly think you went deaf: followed by getting cellular signal and a tow. Or carry tape, sure ties, extra hose in a sealed bag and/or something to read waiting?
Get Happy!
Old 08-31-2016, 08:06 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,255 Likes on 3,627 Posts
The Stock HD petcock has a diaphragm that controls fuel flow plus a rubber valve seal under the lever. Fuel leaking out of the petcock can be the result of a damaged seal, damaged diaphragm or loose diaphragm screws. You need to figure out where the leak is an fix it. Also the petcock may simply be loose on the tank or possibly leaking seal between the tank and the petcock. You can try and tighten the nut.
Old 09-02-2016, 06:27 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Start by following bwoltz's advice.
The vacuum tap does encourage owners to neglect turning the gas on and off. If you can live with doing that then bin the old tap and buy a suitable normal replacement, readily available on Ebay and elsewhere. You can also replace the vacuum tap with another, if you prefer and yours proves unrepairable.
Old 09-02-2016, 06:48 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
get a PINGLE petcock & cap off or just plug the vacuum line
Old 09-02-2016, 01:15 PM
prplglide's Avatar
prplglide
prplglide is offline
^^^ Agree. I've been running w/out a vacuum petcock on my 96 fxdwg for about 15 years now w/out any issues related to it whatsoever.
Anixon88
Exhaust System Topics
16
07-27-2022 06:17 PM
Bikerswine
05-03-2012 05:31 AM
misfitJason
02-16-2011 07:34 AM
DaytonaJoy
07-28-2009 05:02 PM
94-Sporty
06-13-2009 03:03 PM
Quick Reply: Petcock panic
