possible 88 to 124 build
Finally coming to the realization of this happening. Any pros and cons to this?
I originally was just going to stick with a 98" bore with heads and get the crank done, already have cams and cam plate upgrade. (05 deluxe) Then my builder said "for a few extra bucks on the crank you can go for a 117/124 build." No need to pay for the jug bore anymore just buy S&S pistons and jugs. So whats the opinions here? I have heard some things about the cases becoming to thin with a 124 from an 88.
Longivity?
We have a client in Syracuse, NY that has over 135,000 on his 124", almost 1/4 million miles on the chassis.......and that is his "other" bike.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Prodigal_Sun (01-15-2020)
To interject, we pull the stops at 4 1/8" bore as the case bore ends up at 4.322".
We have built engines at the 4.250" bore dimensions with great results, just don't care for the case bore to be that close to the cylinder stud threads.
Master-blaster crate would be a G2 126".
Big hole, big head, BIG rpm.
Scott
Scott
Want to smoke any street Harley you roll up on in your town?
Want to be able to go to any bike night and when someone says "yeah my buddy has a real fast Harley" and look at him and just shake your head and smile?
The 126" crate, stock and properly set up is the ticket. Ran one pretty much stock for 7 hard years-flawless.
I recently modified mine when it finally wore out and I will take it in its new form over the new 143" S&S crate ( in stock form) all day...
