Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
What are everyone's thoughts about adding the hurricane heads to the 110. I already added t-man cams, upped the throttle body and injectors, screaming eagle race tuner and Rush 2 into 1 Reaper pipe. Getting just under 120 hp and 120 torque.
With the T-man cams I would talk with Hillside, Fuelmoto, or a few others on here about what heads would be best to use and if you're planning on going above 120 hp/tq you'd better have the crank worked over.
