Help Needed on engine build
Old 04-26-2015, 01:54 PM
03dragonRK's Avatar
03dragonRK
03dragonRK is offline
Default Help Needed on engine build
Doing a 95 big bore with cams and things are not going well.
I was going to do the cams then the Pistons. Had the cams out when I discovered that I needed a different cam plate ( conversion to the newer tensioners) so I replaced the Pistons and cylinders. I lost track of where the cams to piston relation was.
When I started the bike (2005 Road King) up it ran bad and front cylinder was cool so thinking I was 180° off I pulled the cams and rotated the crank one revalution and tried again. What I got was no fire up and sounded like I was on compression release.
Thinking 4 stroke I again pulled the cams and rotated the crank 1 more turn and tried again, but the results were the same as the last try.
Service manual is no help so asking for Ideas!
Old 04-26-2015, 03:34 PM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
simply line up the marks on the cams,first the inner marks (cams themselves) then the outer chain (pinion to cam sprocket),don't sweat where the pistons are.
Old 04-26-2015, 07:25 PM
03dragonRK's Avatar
03dragonRK
Found the problem!
Adjusting the HD pushrods per instructions caused the intake valves to remain open. Found this when I ran a compression test and the was no compression.
I adjusted them (intake) and now it runs.
Of course the crankshaft position sensor decided to spring a leak on my test drive so will need to replace that before I proceed breaking it in.
Old 04-26-2015, 07:32 PM
r136dg's Avatar
r136dg
r136dg is offline
Like Prodrag said! End result, they have to line up like in these pics. They wont line up like this if you don't get it right pressing the cams in the plate with the inner chain to begin with. Use straight edges. The manual & proper tools are necessity! Take your time & good luck!
Old 04-26-2015, 07:37 PM
r136dg's Avatar
r136dg
r136dg is offline
Posted while I was pasting pics. Glad ya got her figured out!
Old 04-27-2015, 06:29 AM
prodrag1320
you had to be adjusting the p/rods wrong,if you followed the instructions,there wouldn't have been a problem
TDH1904
Engine Mechanical Topics
01-27-2013 03:59 AM
Kaycee
Exhaust System Topics
12-29-2011 12:40 AM
genshovel
06-15-2011 10:05 PM
Phat09flhx
04-21-2011 06:01 PM
jaguar
Ironhead
01-01-2007 09:27 AM
Quick Reply: Help Needed on engine build
