91 ultra glide oil leak
Many gravity feed oil tanks drain themselves into the crankcase when out of service for any length of time.
Such an over abundance of oil cannot be physically scavanged back to the oil bag at that point, and will snot itself out on the ground.
Shy of that, it would be a sheared return oil pump drive shaft key, but you can rule that out if once running, pull the oil filler plug and witness if you have oil returning to the tank.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Sounds like the breather hose. If the motor has a bunch of oil in it because of the check valve leaking by and a gravity feed oil tank, as Scott suggests, oil will blow out the vent when the engine fires until it has expelled all the excess oil from the crankcase. Check the oil level in the tank; make sure it has some in it. You might get a rough idea how much oil has leaked by the pump check valve from how low the tank level is, if that's what's happening.
You should be all right putting the end of the vent line in a catch can and starting the engine.
Also as Scott said, leave the cap off the oil tank and look in there with a flashlight while the engine is running: you should see oil returning to the tank.
