oil pan removal
oil pan removal
1997 road king
My oil drain plugged stripped out so I tried the over sized drain plug but now it keeps dripping it could be that I'm scared to strip it out. I am thinking about replacing the oil pan. Is this a difficult job? I have read it can be removed from the front? I also read there is a spring that needs to be removed on the inside of the pan. Is what I have read true?
Thanks
Thanks
We weld those, and drill/tap back to the OE thread size.
Must've done 3-4 dozen of those now.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
IIRC, there EVO oil pan is not baffled like the TC oil pan which is baffled and the baffle is held down by two pretty strong springs in the front and rear of the baffle. I can tell you from experience that the R/R of an early TC oil pan is a major PITA. When I pulled the pan on my '02 FLHT, I sprung for the later non baffled pan which was breeze to install and will make future R/R, if ever, also a breeze.
Not familiar with EVOs but I doubt the pan can be removed from the front and will have to be removed from the rear. If your frame cross member has not been bent, the pan should R/R from the rear and perhaps the motor may have to be raised a tad not so much for the removal but to facilitate the replacement.
Go to Ronnies Parts Finder and take a look at the pan for the EVO and the TC and you can see what I am talking about.
http://partsfinder.onlinemicrofiche....artsfinder.htm
It's not a difficult job if you refer to a factory service manual! You'd be much better off reading that, then once you have removed your pan Scott can repair it for ya! You can see a breakdown of the parts involved on this website.
