lifter noise
Old 06-16-2015, 08:57 AM
74shovel's Avatar
74shovel
74shovel is offline
Default lifter noise
I have a 2010 cvo ultra 585 S&S cams ,SE roller rockers ,tuned with 45000 miles. At 40000 miles it started making a sound like rocks in a tin can. I had the lifters replaced with fueling HP lifters. I thought it was fixed it was for 200 miles. At that time it started ticking when the oil gotten warm like it had a bad lifter. I rode the bike for another 5000 mile and decided to replace the lifters once again. Fueling warrantied the lifters I replaced them with another set. I set the push rods at 3 turns 96 thousandths like the fueling directions. I have S&S push rods 32 tpi.
Now the bike still clatters when the oil gets warm and at idle. Anytime the oil pressure is under 32 psi it ticks.
Old 06-16-2015, 02:58 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,810 Likes on 3,315 Posts
You can set more preload if you like. Do you know what the total travel of the plunger in your lifters are. If they are .200" you can set your S&S pushrods witch are 32 tpi to 4 full turns and 3 flats which will equate to approximately .140" preload. Or just add one more revolution to the 3 full turns you have now and that should quiet things down and will put you at .125" preload. If not you might have a little too much wear in the rockers.
Old 06-16-2015, 07:06 PM
74shovel's Avatar
74shovel
74shovel is offline
would the rockers be worn out at 45000 mile. possible
Old 06-17-2015, 04:42 PM
98hotrodfatboy
If you have 32 tpi pushrods set the preload to .140" which would be 4 full turns and 3 flats, should get you there.... Yes the rockers can wear but I would reset the preload first. I think that'll get you there....
Old 06-17-2015, 09:13 PM
74shovel's Avatar
74shovel
74shovel is offline
I was wrong my S&S push rods are 24 tpi I set them tonight at 21 flats still taps at idle.
Old 06-17-2015, 09:53 PM
98hotrodfatboy
Are you sure about the 24 tpi. I didn't know that S&S made 24 tpi rods. Heres a link with manufacturer and tpi settings.
http://www.sscycle.com/tech-info/pus...ustment-guide/
Even if they are 24 you can still go 3 more flats.. If you have to, count the threads to make sure.... if they are S&S 32 tpi 3 turns will only put you at .093" and will be noisy at idle.
Old 06-18-2015, 06:10 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
We use S&S valvetrain components here w/o issues whatsoever.
We load the S&S lifters to .140" to keep valvetrain noise to a bare mimnimum even during thermal expansion at full operating temps.
A Baisley spring, or Zippers shim in the early cam plates, along with the proper viscosity oil as stated in the HD service manual for the ambient temps the bike will be operated in, also helps.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 06-18-2015, 07:10 AM
shorty07ultra's Avatar
shorty07ultra
shorty07ultra is offline
So Scott if I am reading correctly. You set the s&s a djustibles at Four full turns and four flats. Reason I ask was I am running the 583 EZ starts and was adjusting to four full turns and it seems like excessive valve noise set to this spec.
Old 06-18-2015, 09:46 AM
74shovel's Avatar
74shovel
74shovel is offline
I put a 5/16-24 nut on the adjusting screw and it went right on ,didn't bind and ran right on down. I am about ready to through the Fueling lifters in the trash and buy a set of premium S&S lifters
Old 06-18-2015, 10:50 AM
Hillsidecycle.com
Sponsor
I'd have to bet good money that an S&S lifter would quiet things down, unless of course there is something else going on.
Scott
Quick Reply: lifter noise
