Safe Cleaner/Solvent for Wrinkle Black engine
Old 07-06-2015, 06:50 PM
Nick412's Avatar
Nick412
Nick412 is offline
Default Safe Cleaner/Solvent for Wrinkle Black engine
Long story short... Fixing pry slot leak on 07 night Train that has a wrinkle black finish on the engine. I was skeptical about brake cleaner so I tested it on the bottom of the engine where there were already a few scratches. Took the black finish right off. I need to get this pry slot properly prepped before I try and seal it up with some wicking grade loctite and ultra black gasket maker. I have been using q tips and isopropyl alcohol for about an hour and I still get oil and dirt everytime I take out the q tip. I need the pressure and evaporation of brake cleaner without taking off the finish. Is there anything that meet my requirements? 3 different harley dealers are clueless. They use high end brake cleaner that's only sold in mass quantity.
Old 07-07-2015, 07:14 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
We use mineral spirits here in a re-chargeable canister.
Works for us.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 07-07-2015, 09:49 AM
RKGDCG03's Avatar
RKGDCG03
RKGDCG03 is online now
Isopropyl alcohol also works well and will not affect the finish. It is also available at almost any grocery or pharmacy.
Old 07-07-2015, 11:57 AM
Nick412's Avatar
Nick412
Nick412 is offline
I have been trying 70% isopropyl alcohol with a syringe but the alcohol cracked the plastic in the syringe. I definitely need something that can blast in that hole cause every time I take the q tip out there is grit and oil on it.
Old 07-07-2015, 01:23 PM
Rat Trap's Avatar
Rat Trap
Rat Trap is offline
Wd-40
Old 07-07-2015, 01:24 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
Try an aerosol Mass Air flow Sensor cleaner.
Old 07-07-2015, 01:33 PM
Nick412's Avatar
Nick412
Nick412 is offline
Originally Posted by Rat Trap
Wd-40
I have tons of wd40 I could use. I am thinking of blasting it out with wd 40 then pouring the rubbing alcohol in to clean the wd40 residue. that residue was the only thing I was concerned about because I need it as clean as possible for the Loctite to wick in.
Old 07-07-2015, 05:09 PM
Nick412's Avatar
Nick412
Nick412 is offline
Day two of the dreaded pry slot battle... Found a small ear wax baster which is the perfect size for the area. Good news it blew out some grit. Bad news... Still some oil left in the hole.
1LargeDog
10-23-2018 10:51 AM
chuck2000RK
Detailing
07-20-2008 10:40 AM
Skylark
Detailing
05-27-2007 12:01 AM
HarleyJedi
Detailing
06-22-2006 10:29 PM
Newkid52
05-27-2005 03:19 PM
Quick Reply: Safe Cleaner/Solvent for Wrinkle Black engine
