Woods 999-6A Cam? Anyone?
#161
Hi, can I ask how your cam performs in slow traffic as I simply chug along and have to downshift to avoid the lugging effect of these cams? An example is even at 50mph, I have to downshift to say 4th or sometime 5th whereas a lot of riders I run with are still in 6th holding their own?
The following 2 users liked this post by cdonis:
Max Headflow (06-01-2018),
robatrak (05-29-2018)
#162
Appreciate knowing if others feel the 999 cams chug at low speeds or is it just me? I have to ride above 2500-3000 before up changing gears otherwise they the engine lugs, is this about right? At the higher range, they are awesome but I don't always ride at the hi-end of the revs.
#163
Was chatting with fuel moto and they said this is the cam to go with for a bolt in on the 103 Rushmore. Looking for anyone who maybe running this cam with some insight. (More than likely going to use it on my 2015 street glide special.) Or for the cam guru's out there here are the specs.....
Open Close Lift Duration TDC Lift
INT 26 46 .575 252 .230
EX 46 26 .575 255 .225
http://www.fuelmotousa.com/i-2085965...ECIAL%20FLTRXS
#164
#166
#167
My 999-6a cams don't lug or stall or buck at all until you get down around 1000-1200rpms or so. The driveability is the same as my Andrews 57H cams were. It was tuned on a SuperFlow load-bearing dyno by Jesse at Busted Knuckle in Walnut Cove, NC.
Now camchest noise is a different issue altogether. I've tried Wood, Feuling, and S&S lifters in it and none of them were any different. Top-end noise, not a peep, but you can definitely tell there are cams in it.
mirrmu (06-06-2018)
