Lwr Front Rocker Box Gasket
Old 07-25-2015, 12:14 AM
joejoe75's Avatar
joejoe75
joejoe75 is offline
Default Lwr Front Rocker Box Gasket
I have a 2011 Deluxe with a little weeping oil leak on the front lwr rocker box. I'm wondering if I need to disassemble the the push rods to get to the lwr front box off. The service manual says to take them off for a top end overhaul but im just replacing the top & lwr front rocker box gaskets. As long I get the motor TDC will it be ok to not disassemble the push rods to get the lwr front rocker box off?
Old 07-25-2015, 12:31 AM
ntraindavefl's Avatar
ntraindavefl
ntraindavefl is offline
TDC on the exhaust stroke makes for easy, safe gasket replacement.
Old 07-25-2015, 08:00 AM
northeastconfederate's Avatar
northeastconfederate is offline
No need to remove pushrods, just lift the rockers off and the lower rocker box off over the pushrods. Do it on the compression stroke and both valves will be closed with lifters/pushrods at lowest lift. No fancy footwork required.
joejoe75
07-24-2015 08:28 AM
dsturch1
08-10-2014 06:43 PM
feguy1
Exhaust System Topics
08-12-2012 04:41 PM
hddee
04-22-2009 11:38 PM
fatbob
09-17-2007 11:49 PM
Quick Reply: Lwr Front Rocker Box Gasket
