Late Model Twin Cam, How much lift before clearance case?
Old 09-03-2015, 01:42 PM
nottaway's Avatar
nottaway
nottaway is offline
Default Late Model Twin Cam, How much lift before clearance case?
How much lift can you run without running into cam lobe clearance issues on the late model twin cams?
Old 09-03-2015, 02:14 PM
djl's Avatar
djl
djl is offline
Received 2,030 Likes on 1,498 Posts
Don't know for sure but the SE260 and SE266 cams have lifts of .609" and .658" respectively and there is no note in the SE Performance catalog that cam chest clearancing is necessary. The SE266 cam shaft is used in the 113" Stage IV Race Kit and SE120R engines. I can tell you that in the early models cams with more than .590" lift required checking to make sure the clearance between cam lobes and the main bearing boss housing as well as the bottom of the lifter blocks was at least .030" and cams with more than .600" lift definitely required clearancing.
EDIT: I ran 590" lift cams in my '02 FLHT with no clearancing; however when I repaced them with .600" lift cams, there was not .030" clear between lobe and the upper corners of the main bearing boss housing and I had to clear.
Old 09-03-2015, 02:33 PM
nottaway's Avatar
nottaway
nottaway is offline
I have heard for sure that 650-660s need machining for sure on late models.
However, I wonder if something like a 625 would be ok?
Old 09-03-2015, 02:39 PM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
anything over .570 should be checked.ive had cases where .625" had clearance & others where 585`s needed to be machined.rule of thumb,check,dont assume
Old 09-03-2015, 08:16 PM
dynawg1's Avatar
dynawg1
dynawg1 is offline
Using .619" lift (Crane 296) cams in my 2000 TC with no clearancing.
Old 09-03-2015, 09:25 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
I've got 9F's spinning around with no grinding BUT doesn't the base circle determine how tall the lobes are? So some cams with the same valve lift might have taller or shorter lobes than others, right? Or am I way off base?
Old 09-04-2015, 09:31 AM
djl's Avatar
djl
djl is offline
It's too easy to check and remove the guess work, so if you want to install .625" lift cams, plan on checking and if the case needs clearing, clear it. Don't forget valve springs either.
Old 09-04-2015, 12:28 PM
dynawg1's Avatar
dynawg1
dynawg1 is offline
Right on both counts.
auburn08
Engine Mechanical Topics
08-16-2015 07:30 PM
CYCLE1949
Ironhead
02-19-2014 09:03 PM
BadBagger08
Exhaust System Topics
02-25-2011 11:02 AM
bigjoe1
10-13-2010 05:20 PM
voodoodrug
08-18-2010 10:07 AM
Quick Reply: Late Model Twin Cam, How much lift before clearance case?
