Tman 625 cams
Have never run the 625 but currently running the 600SM in my all bore 107" motor (4.125 x 4.00) in a 2002 FLHT, CV44 carb, ported heads, FM head pipe and 4" Jackpot muffler, moderate compression and I like the cam. 124TQ/110HP and 100TQ by 2000 rpms; what's not to like? You might need more than stock compression to get the most from the 600SM. Mine is set up at 10.4 static and a 107" motor with stock head gasket will be about 10.2; not much difference though and I wish I had pushed mine to about 10.6. Listen to Doc, pretty smart guy.
I have an all bore 107 with the 600SM, at 10.5 comp. with Baisley Super Stock Plus heads, 55mm HPI with 5.3 injectors. 120/123 HP & Torque and 100 lbs. at 2000 rpm. I don't think you will be disappointed. The 625 probably needs more compression, throttle body, head work etc. to use the cam effectively.
There is only a 1.0 / 0.8 (HP / TQ) difference between an all bore 107" (106.9 ci) and a longer stroke 107" (106.5 ci) when everything is the same (CR, cam, exhaust, etc.).
With a shorter stroke, the all bore should rev quicker and have a lower piston speed?
parts eeter
04-25-2013 10:02 AM
