Erratic Oil Guage
Easy and cheap fix. R/R cam plate; pull relief valve out and buff it up so that it travels freely in the bore; no $$, just a couple of man hours. Replace tensioners with CYCO units; IIRC about $40 for the pair and a couple of more man hours. Most expensive purchase would be the service manual for your bike, which, if you don't have, you should have.
............might as well............
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
I just called HD for craps & giggles to see what they would charge for this job. Their Master Technician with many years, certs, and etc... says I must replace my cam plate with billet, new oil pump, etc. Minimum cost will be $1200 before he sees what other damage has been done to my engine. I guess I'll be doing it myself after all. I'm more cheap than I am lazy. I did my own cam swap in my 2011 Ultra so I know the work isn't difficult. I just no longer have a good place to do the work like I did at my last house and many tools still in boxes somewhere. So I need to assemble a parts list:
New oil pressure relief spring/valve (not sure I know how to properly buff/polish)
New adjustable push rods (since I'll be cutting my old ones)
Gasket kit
New cam tensioners if needed
fluids
Anything else?
Gasket kit
fluids
Anything else?
