Worn lifter bores
What was the lifter/lifter bore clearence dimemsion that your friend had measured?
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Lifter fit in block are loose fit at .0008 to .002 which is truly not much clearance and actually important for oil pressure. All that oil in that area amazes me they would wear much let alone groove. If you do not have measuring tools, stick a 1/4 wide strip of note book paper beside it and see if lifter will shake. However, if grooved, that will let oil not go thru lifter and up thru push rod but escape around and drop back into cam galley. Lifter will not pump and surely starve rockers up in the head.
