08 Ultra Classic starter noise
Old 10-20-2015, 09:20 AM
alcris47's Avatar
alcris47
alcris47 is offline
6th Gear
Default 08 Ultra Classic starter noise
I brought my bike to a local repair shop to correct a noise in the starter, they replaced the ring gear, starter clutch assembly and replaced the auto primary chain adjuster and I still have the same noise, it kind of a grinding noise that is worse when the bike is warm.... there are only 20,000 miles on the bike any thoughts????
Old 10-20-2015, 11:23 AM
cherry686's Avatar
cherry686
cherry686 is offline
I have a buddy , actually 2 buddies , one with an 08 SG and the other with an 08 Ultra . Both have had compensators and starters replaced, but both motors also have cams and no compression releases. If your bike is stock than it may be an issue with 08 's.
Old 10-21-2015, 05:49 AM
alcris47's Avatar
alcris47
alcris47 is offline
6th Gear
Yes my bike is stock, I took it back to the shop and they told me the new ring gear and starter drive need to wear in as the tolerances are so close that it will make that noise till they "wear in" hope it does or I'll be back....
REPO1
08-27-2014 10:48 AM
lunyty1
06-20-2013 05:53 PM
rkoivisto
10-08-2012 07:57 AM
Jukebox
04-24-2012 09:28 AM
bdp
06-19-2009 01:06 PM
Quick Reply: 08 Ultra Classic starter noise
