1.7 ratio rocker arms? Whats the deal?
So I understand the difference between 1.6 and 1.7 ratio, I get the fundamentals of lever advantage ratio.
So my question is actually about the application to harley twin cam engines. Changing the ratio increases lift and the effective duration. However the centerline of the cam lobes stays the same. So the 'timing' of the cam is the same just increased lift and effective duration.
If one were starting from scratch ideally you would just get the cam with the lift, timing, duration, etc that you want but I am curious how they can be used with lower lift cams to get increased lift and duration. Say you already have the 1.7 roller rockers laying around.
I'm considering a set of 1.7s for my Tman 590 so lets use my configuration as an example:
1. Are they an effective tool across the board or are some cams best suited for this application?
2. Shoule I install on the intake and exhaust or just the intake?
3. What are the negatives of this type application?
From what I have read
1. Are they an effective tool across the board or are some cams best suited for this application? Some cams will benefit while other's probably not.. I think the stock epa cams are in the not category.
2. Shoule I install on the intake and exhaust or just the intake? Depends but for the most part both or just Intake. Most say when talking about OverSized Valves that the Twincams Intake is the key one.. obviously as you are trying to move up in power they both need it at some point. This thought seems to hold true for the Rockers as well.. get more air into the engine first, at least in the case of the Twincam
3. What are the negatives of this type application? I think mostly the same as Higher lift cams
One thread I'd seen says that Baisely will sell just Intake or Exhaust
.030" more lift, and aprrox. 2-3 degres more duration.
Some cams really like them, and others do not seem to.
S&S .585's and .570's, .510's, respond well, and Wood 6's do also.
Wood 9B's or the 9F's don't, just for instance.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Ryan Poe (09-10-2023)
Hillsidecycle.com (04-17-2021)
Just curious why they would not work well on the epa cams? Have thought about doing this with stock cams as it cheap. But no use in doing it if no gain to be had.
It's not that they won't work. There will be a slight improvement but not enough to warrant the work....The shorter duration or epa cams won't because it's more about the amount of time the valves are open. Longer duration cams benefit better from the lift because of the length of time that they are open to an extent as Scott noted. More fill..
The following 2 users liked this post by prodrag1320:
Hillsidecycle.com (04-17-2021),
