Pan / Shovel
Old 12-03-2015, 09:32 PM
32roadking's Avatar
32roadking
32roadking is offline
Default Pan / Shovel
Anybody know if Pan heads will work and fit on a 69 FLH Shovel?
Old 12-03-2015, 09:59 PM
nomad billy's Avatar
nomad billy
nomad billy is offline
Depends on what yr heads,but in short no.The oiling system is different depending on yr. 65 outside oiler's will work or some aftermarket repop's would.But anything can be made to work with patience and the right book's.
Old 12-04-2015, 06:10 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
They'll fit in the chassis, and on the engine.
As already said, just need to configure the oil lines.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 12-08-2015, 10:32 PM
32roadking's Avatar
32roadking
I found a 69 Shovel with what looks like a Pan lower, this is the bike id like to put the Pan heads on. Maybe the S&S Pan heads. Thanks guys.
Old 12-09-2015, 06:11 AM
Hillsidecycle.com
Sponsor
A 1969 FLH had a genetator bottom end.
1966-1969 was the production run of that engine.
Cast iron pump on the 1966-67 models and then the aluminum pump on the 1968-69's.
They are not rare, but you do not see them as much anymore.
I'd leave it as a generator Shovel if it we me. JMO.
Scott
Old 12-12-2015, 07:20 PM
32roadking's Avatar
32roadking
Thanks Scott, I've got wood 4 a Pan head.
Old 12-15-2015, 11:45 AM
Hillsidecycle.com
Sponsor
I hear ya'.
Scott
Old 12-15-2015, 02:11 PM
wfolarry's Avatar
wfolarry
wfolarry is offline
You'll need the cylinders too.
Old 09-04-2020, 06:13 AM
62 Pan Shovel's Avatar
62 Pan Shovel
62 Pan Shovel is offline
Incorrect heading, a Pan Shovel is a pan which has the later shovel heads fitted, thus only a pan may be called a Pan Shovel
Old 09-04-2020, 06:24 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
oiling is easy enough to set up on heads needing it,if not worried to be year correct (which it isnt stock anyway) going with S&S panheads would be a lot easier & end up with better heads anyway
Quick Reply: Pan / Shovel
