Borrow some tools for a cam swap?
I'm about to do cams on my '06 FLHT, hoping to avoid buying the inner and outer bearing tools if possible. I have a shop press for the cam plate bearings. Anyone have the tools that would rent or let me borrow for a few days? Looking at New Years weekend as I'll be off a few days. Thanks for considering!
There is a work around to R/R the inner cam bearings. I used it a couple of times until I started helping friends and family with cam installs and bought the tool. I call it the "cave man" work around.
AutoZone rents a blind hole puller; just check the case and make sure the correct size collet is there. Take one of your new bearings or measure it. You can push the new bearings in with one of the take out cams. Freeze the bearings over night, liberally apply assembly lube to the bearing cage and bore. Install the bearings numbers facing out; the back side has a chamfer to facilitate getting the bearing started straight in the bore which is the key to a successful install. Use the take out cam to tap the bearing into the bore. When done, insert your pinkie into the bearing and roll the rollers to make sure none are in a bind and all rolling. Boom! Go have a beer and find something else to do with the money you saved on tools.
Of course, if you can borrow the R/R tool, do it. Just saying you don't have to purchase a tool that you will very likely only use once.
__________________
NO, they DON'T all do that!
Also on amazon.com...
Illustrated step by step link is attached. Install is for gear drive cam but the basic method is the same; see page 2-3.
http://harleyhog.host.sk/1550/bbonline03.htm
