Painting Edges of Cylinder Fins
I have the bike stripped down with the rocker boxes and pushrod tubes sent off for powder coating. I don't really want to remove the cylinders and wondering if anyone has painted just the silver edges of their cylinders. If so, how and what did you use?
Wonder if this and a model paint brush would work. Tedious, but ....
Tedious? Very, I had heads and cyls on the bench. Results were so so. Didn't last, constant touch ups made it look like crap. I know preparation is everything, did my best. Others have had no problems...up to you....feel lucky?
I recommend buffing up the silver edges then applying S100 Engine Brightener to the black sections. Really brings up the contrast.
Jim
Jim
Jim
Jim
I saw a youtube guy spray the cylinders with a high temp wrinkle black (more forgiving appearance wise) and came out real nice. Touching up just the edges will come out a bit ghetto especially over time.
To clean up rusty fins, a super fine sand paper is best, then keep the anti corrosion s100 applied on the regular.
First I did the edges, started to look like crap, then spray painted entire Cyls. Paint started to lift off in finger nail sized patches after one season. If you paint your Cyls its like painting a wood deck. You have to keep repainting every year or two. Plus when you do, it's not like you can completely remove the previous coat. Go ahead roll the dice, it sounds like you want to do it, just waiting for enough guys to say it's great.
Get them done right. Powder coated then done.
