Lefty bearing VS Timken
DJL,
There are a metric **** ton of 107's making good numbers on stock cranks. I'm beginning to think how you ride has something to do with crank life. I agree we shouldn't need to have these conversations if the mother ship was doing cranks right. The biggest problem I have read about 120's has been jugs out of round from the factory some cranks also but brand new cylinders out of round. If I dropped the coin on a 120 and the bores were messed up right from the rip I'd be wanting a big chunk of someone's *** for sure.
DJL,
I am certain that how one rides has something to do with crank life but also am certain that some crank failures are "baked in the cake" from the factory and the poor sap that buys that motorcycle takes it in the shorts if crank runout shows up to be .010" and the bike is unrideable. Regardless of the metric ton of 107" motors making good numbers on stock cranks; you should be able to count on the stability of a crank shaft when paying $20K for a motorcycle and with the HD brand, you just can't do that. That's my issue.
You would think a company that has been boring cylinders since 1903 would have it down pat by now, WTF?
So where are all the posts about failed "leftie" bearings??
In a race motor that lives it's life at red line I get it, street motor that rarely sees max rpm under heavy load (ie:top gear) if ever is the added expense warranted? Now I'm sure the guys who do the conversion will swear by them and I don't blame them a lot of labor with low parts cost = great margins on the work.
No one is laughing all the way to the bank here.
The only reason the Moco went the route of the rollers is them cheaping out on YOU, the end user.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Trust me, there is a good deal of expensive parts, plus the machinery, plus the fixturing/tooling purchases in order to establish precision Timken bearing conversions.
Scott
Scott
After the purchase of the sleeve, seal, Timken bears, and crank spacer, that leaves us with approx. $93.00 left on the table to remove the old bearing, clean and prep for machining, press the sleeve in using very expensive Loctite,
set up in one of our milling machines and c/drill, drill, tap on location/bolt circle, install the screws w/Loctite, set up and establish oil feed hole, set up and establish oil drain hole, clean, install Timken races, set bearing end play.
Our machine shop is extremely reasonably billed out at $80.00/hr., and in no way, can we perform that work in 1.16 hrs.
I've been in this industry for 30 years and have been a NYS Certified Toolmaker for 35.
More of a service we offer, than a money-maker.
A guy with an Estwing hammer/skill saw/ladder rack/magnetic signs on his p/u truck makes more dollar/hr. Fact.
Fathead Fool (11-26-2023)
