Simple lifters/pushrods question....
OK, so I have changed the cams in my '14 FXDF to Andrews 57H, and am just waiting to get my heads back before buttoning the bike up.
I have replaced the stock "C" lifters with Comp Cams 850-1s, and will be using the S&S Quickee adjustable pushrods. I've never installed adjustable pushrods before (or swapped cams for that matter), but everything I have read about installing the pushrods says to make sure that the lifter is on the base circle for the pushrod you need to adjust, take out the slack from the pushrod, adjust the pushrod the required number of flats - and WAIT FOR THE LIFTER TO BLEED DOWN.
Now....the lifters are new - so how can I know if they are pumped up in the first place or not. I'd have to assume that they are pretty much bled down from time in stock, in transit and the few weeks they have been sitting in the bike anyway, right? They've been at atmospheric pressure since they were manufactured, and who knows how long ago that was?
So, given that I can't run the engine to pump them up in the first place, is it just a matter of take up the slack, adjust the pushrods the required number of flats, leave the lifters for a while to bleed any oil that is in there out and it should be good? In other words it's really setting the pushrod length against the spring in the lifter rather than any particular hydraulic pressure?
Sorry if this is a stupid question, but I'd rather do it right the first time!
I recently installed the same pushrods as well as S&S premium lifters. With cam at base circle extend the pushrod by hand until you get out all the slack . I run mine at 4 turns and 3 flats. I then removed the spark plugs and unplugged the fuel pump then crank it over a few times for at least 10 seconds and that will pump up the lifters some but it will rattle until all the air is bled out.
I'm thinking the same way - I already have a set of "rocker lockers" on the bench ready to go in.....
Keep an eye on the pushrods rubbing on the bottom of the pushrod tubes I ended up using the top tube from the OEM and the bottom tube from the kit. The OEM top tubes are about an inch shorter giving enough clearance for the collar to clear.
I am going to install new lifters also. I was wondering if I could submerge them in oil and pump the push rod end until it quits pushing out the air? I was thinking of using a capped piece of pvc pipe in a vice so I do not chase the roller. Will that work or is it a bad idea?
EDIT - After reading with the engine apart, now I get it. It needs to bleed down. It is written everywhere. I do not know why I had to hold the lifter in my hand to understand. It is a bad idea.
HardyHarHarley
Exhaust System Topics
09-03-2010 09:00 AM
