120ST Tman 660SM
120ST Tman 660SM
Thundermax with auto tune, R&R cam plate with Zippers tensioners, Fueling lifters, S&S quickie pushrods and TP engineering pro roller rockers are on there way along with Tman 660SM cams and .030 head gasket. Stock, I was sitting at 111hp/118tq. I'm looking for around 125-130/125-130. Does that sound doable? 120ST has a 58mm throttle body and 5.3 injectors, running a Propipe. Thoughts?
Should be able to accomplish the task. Checking on another forum, I seen two 120st motors both having D&D Boarzilla exhaust and they pulled 125/135 and 128/141 with a good tune and exhaust. Thinking your exhaust might be on the small side (regular or Hi-Output?) but, will push the curve to the left a little and won't see those peak numbers.
Never worked with that cam, but I do know that a Wood 9B plug/play, will push the torque up into the mid-130's.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
