Drago's Bikeworks Cams
Old 02-11-2016, 03:03 PM
InthewindMN's Avatar
InthewindMN
InthewindMN is offline
Default Drago's Bikeworks Cams
Has anyone tried the Drago's 565 or 580 cams?
Old 02-11-2016, 08:49 PM
Nightrain04's Avatar
Nightrain04
Nightrain04 is offline
I have the 565's in my 2012 RG. What would you like to know?
Old 02-11-2016, 09:52 PM
InthewindMN
Stock motor otherwise? How do they perform?
Old 02-12-2016, 12:15 AM
Nightrain04
No headwork. Just 103, Rush h pipe, and big louie mufflers. I'm happy with them. I believe he offers your money back if you install them and are not happy. He is a good guy and will take time to discuss your build with you.
I am getting ready to install a set of 48h from andrews in 103 in a couple weeks so I will have something to compare to.
Old 02-12-2016, 05:41 AM
billablehours's Avatar
billablehours
billablehours is offline
Does your Dyno graph just show what the tune did? Looks like the same set up was run both times.
Do you possibly have a graph in SAE instead of STD and with a 5 smoothing to compare to most other Dyno graphs?
Old 02-12-2016, 06:18 AM
Nightrain04
From what u was told, this particular tuner uses std. First run was from the map I took it to him with. 2nd was what he ended up with. Only have graph I have is std. I was told my tuner was old school using std. It runs like a top.
I have no problems with what he did. Its about ride ability, not what lines on paper are.
Old 02-12-2016, 09:07 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,808 Likes on 3,313 Posts
What are the numbers on that 565 cam? Interested in the difference with the 48.
Old 02-12-2016, 11:13 AM
Nightrain04
http://dragosbikeworks.com/cams/2497950
Here are cams specs. Not as much lift as the 48s I believe. And about $150 price difference.
Old 02-12-2016, 12:27 PM
InthewindMN
Nice torque curve, looks like fun to drive!!
Post those 48 numbers when you get them please. Thanks.
Old 02-12-2016, 12:47 PM
Nightrain04
Will try to post #'s. Will use a canned map till dyno tune. Weather is still pretty foul around here. Ended up scoring a used set of 48h's with 3k miles for $110.
mrsnipy
03-08-2019 10:45 AM
rauchman
Engine Mechanical Topics
21
04-07-2018 09:20 PM
Bowhunter61
12-21-2015 06:35 PM
brettnbama
11-22-2010 11:45 AM
Parkerhd36
05-13-2009 12:29 PM
Quick Reply: Drago's Bikeworks Cams
