Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
maybe someone can help me i just bought a 2002 fatboy and when i go into first and let go of the clutch and brake it just goes without me touching the throttle is this normal my sportster didnt do that
The bike is creeping when put in first with the clutch lever pulled in? I don't really follow your statement, it reads as if you are dumping the clutch with the brake being held. If that were the case the bike would stall...If what I described is happening your clutch is too tight and needs to be adjusted properly.
Obviously when in gear and the clutch is engaged and the brake is released the bike will either start moving or stall out. Maybe I don't understand your question.
