Can I get these cams (and parts) to work together???
Can I get these cams and upgrade parts to work together???
Hey guys. Bought a buncha parts that I thought would work together, but I'm starting to have my doubts.
Bike: 2001 FXDX TC88
SE cam chain tensioner upgrade kit (hydraulic)
Andrews 26N cams
Feuling lifters (don't have the model # in front of me)
I wanted to replace the cam chain tensioner system, and while I was in there, give myself a bit of jump.
With the list above, I thought all I'd need is the inner, roller style cam chain.
I was wondering if I'd need to replace the outer chain with the narrower, roller style as well, or if I could keep the wider chain.
(I know if I do need to replace the outer chain, I also have to replace the sprockets with the one with the ignition trigger.)
I called Andrews for answers, and maybe I didn't explain myself properly, but their tech guy said that the abovementioned parts would not work.
Any advice/list of parts required would be a big help.
Please and thanks.
Andrews 26N cams
Please and thanks.
So if I buy this
http://www.ebay.com/itm/CAM-PLATE-Do...lWOrfm&vxp=mtr
Can I attach the hydraulic tensioners from the SE kit?
And then all I'll need is the roller chains right?
So if I buy this
Which part # do you have?
It appears that there are a couple of SE upgrade kits available. Which one do you have?
This thread may help…
https://www.hdforums.com/forum/exhau...er-option.html
I have the 25284-08 plate.
I've just been reading some info from other posts and google and maybe I'm tired but my head is swimming.
So now, besides being frustrated at having to buy more parts than expected, I'm trying to figure out what's gonna cost (and hurt) less:
- buying another set of cams to fit the 25284-08 cam plate
or
- buying a 25358-06A (07+) cam plate
Which seems like the cheaper option, but leaves me wondering:
can I still use my outer (wider, stock 2001) cam sprocket chain and sprockets
(Will they fit? Will they adversely affect hydraulic performance?)
or will I need to replace those sprockets and chain for a thinner roller chain?
and will the oil pump from my 25284-08 kit fit and work?
or
Those cams are $400+ up here in Canada.
https://www.canadasmotorcycle.ca/and...ts-288121.html
Your cheaper option may well be to get the ebay plate, roller chains and gears and sell what you don't use from the kit. I paid $700 Canadian for the 25284-11 locally.
If you decide to go with the silent outer chain setup you will need a sprocket with a splined drive and cam position sensor. I have one surplus to my needs, PM me your address and I will mail it to you. That being said, you already have the roller-style cams, it makes more sense to me to run roller chains throughout.
Good luck whichever way you go!
Kijiji cams in Ontario
