question - any internal breathing issues with using torrington cam bearings in 2013 TC stock motor / 57h cams?
Heard that going to torrington bearings in the current TC motor can cause oil/air breathing issues since the motor uses the gaps in the INA bearings as part of the internal breathing system. the torrington caged bearing design sort of plugs that up (apparently).
Is there merit to this / any of you builders been seeing excessive blow-by or other oiling issues associated with use of torringtons? I have a set of 57h chain cams going in, stock motor. will also be using johnson/hylift lifters, stock cam plate and stock oil pump. about 4k miles on bike total. will not do any motor work beyond cams.
Is there merit to using the Axtell oil bypass kit, and/or the SE oil pump and cam plate with a mild cam upgrade? Any seasoned advice from knowledgeable engine builders is appreciated. I know Evo's inside and out but TCs are still new to me in respect to their specific quirks, gotcha's, etc.
Heard that going to torrington bearings in the current TC motor can cause oil/air breathing issues since the motor uses the gaps in the INA bearings as part of the internal breathing system. the torrington caged bearing design sort of plugs that up. Is there merit to this / any of you builders been seeing excessive blow-by or other oiling issues associated with use of torringtons? I have a set of 57h chain cams going in, stock motor. will also be using johnson/hylift lifters, stock cam plate and stock oil pump. about 4k miles on bike total. will not do any motor work beyond cams.
Never heard that the full compliment bearings can cause breathing issues in the TC motor. Would like to know how the INA bearings facilitate crank venting; always keep an open mind and ready to learn but don't see any issue here. Sounds like one of those things that the "over thinkers" come up with in their spare time.
I have not used the Axtell bypass kit but, in principle, it sounds like a decent piece of hardware but, IMHO, more of a "nice to have if you want one" option than one needed for a cam only upgrade. I like the SE billet plate/pump upgrade for the later models but, again, more of a nice to have upgrade than a needed one. If funds are available though, why not? Better money spent there than on a piece of eye candy chrome. Not a fan of the Johnson lifters; S&S standards would be a better choice IMHO................
Install the upgraded bearings, OE pump, OE plate, S&S std lifters, a good adjustable pushrod loading the lifter to .140", and the cam that will work with your riding wants/needs.
No more complicated than that, and if anyone is telling you different, I'd do an about face, and walk quickly away from them.
No time for such nonsense.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
rauchman (03-21-2016)
Scott
Scott
Do you see any issue with using the johnson/hylift lifters? I essentially have a free set here, the specs do seem better than the stockers and I could not find any negative reviews. Previously I've always used SS.
Yeah, there were 96" softails in 2013. Just to clarify my comment on cam choice, I was not suggesting that the 57 cams will not work or are not a good choice; just a personal bias I have toward more compression than the 57 will generate as a cam only upgrade in a stock compression in a 103"...............
Scott
Scott
A local Indy has had several of the newer models come in for cam upgrades and found aluminium stuck to the crank from the plate. I would imagine the larger runout spec on the crank doesn't help. Anyone else seen that?
