Softail Slim 117" build
Picked up build from shop the other day.
117 axtell cylinders
10.5:1 Pistons
190ccp
110 heads ported and polished
Woods tw8-6 cams
58mm se throttle body
4.9 injectors
Crank pinned,welded and balanced
Dyno chart shows 125hp and 131 tq. These are uncorrected #'s.
Pulls strong 3200rpm and up but seemed lazy to me down low so I sent it to Joe's cycle for him to tune in hopes he can wake it up a little.
10.5:1 Pistons
190ccp
Woods tw8-6 cams
4.9 injectors
The Wood 8 would show it's teeth more, and increase low-mid power, at 200 psi ccp.
No fear at 200 as 110" CVO's come off the showroom floor between 205-207 psi ccp.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Life @3200 rpm is very typical of that cam....but will keep carrying to 6500 rpm or more without a blink.
The tuner won't help the low end really. It's a cam timing/compression issue. If you are unhappy with the lower end then first off the builder should have known 10.8 is that cams sweet spot or even 11.0.
Nevertheless it may not be bad enough to change anything, you may get either used to it or just keep the RPMs over 3k whenever you can.
Short of shaving some off the heads or swapping cams to one that suites 10.5 comp you are stuck with it. I do like the whole set up choices for a 117, just should be at 200 ccp as stated.
Went to pick up the bike from Joe's cycle last Saturday after having it re-tuned. The initial run at Joe's cycle showed 117hp and 131tq. These #'s were lower than the engine builders uncorrected peak numbers. Joe's Dyno chart now shows 131hp and 143tq and 120tq @ 2000rpm. I know these are uncorrected #'s and I know of all the talk about his Dyno but that's a big difference. The torque curve is much improved between 2000 and 3200 rpm and that's what I was hoping for. So I'll ride it hard this summer and have some fun.
