Fuel Moto
Old 04-05-2016, 09:21 AM
Lunchboxx's Avatar
Lunchboxx
Lunchboxx is offline
Default Fuel Moto
I am thinking about doing this
http://www.fuelmotousa.com/p-28614-98-big-bore-kit.html
I ride an 01 Road Glide with Magnetti Marelli EFI a Thunder Header and PC-V. Would the MM EFI be sufficient? and would my stock heads be ok until I can get some head work done? One more Question With 10:1 Compression would I need compression releases?
Thanls
Jeff
Old 04-05-2016, 09:35 AM
Primetime_2's Avatar
Primetime_2
Primetime_2 is offline
call them up
Old 04-05-2016, 01:47 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
Received 4,104 Likes on 1,339 Posts
I answered your request on another forum, you are welcome to contact us for more info.
The MM EFI will work as long as everything is currently in good working order. You can use your stock heads however there are some considerations such as springs & seals that should be attended to as a minimum, and I would recommend compression releases. For best information of this nature I would recommend contacting us at 920-423-3309 so we can get more details on your bike, how many miles are on it, etc.. and provide our best info based on the specific objectives you are looking for with your build
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old 04-06-2016, 06:01 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Thanls
Jeff
Hi Jeff,
I answered the questions in detail in regards to the MM and heads on the RG forum, except the releses, and yes, you'd want releases at 10.0 cr.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 04-06-2016, 06:11 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
we`ve used MM t. bodies on many 98" builds.(even used it on a 124" once),for a milder,touring build they`ll work OK.i would recommend mild 1.900 headwork though.10.0-1 wit S&S .570 ez start cams would be my recomendation
Old 04-06-2016, 06:35 AM
Wide Open Cycles's Avatar
Wide Open Cycles
Wide Open Cycles is offline
Former Sponsor
I've tuned a number of pretty big builds with the MM, did a 135 HP 113" last summer actually. HPI does make a really nice conversion TB for MM though. I just got one for a bike that's in the shop right now. Kind of pricey but uses Delphi injectors
Old 04-06-2016, 07:59 AM
prodrag1320
the HPI single throat really is the way to go for bigger inch,higher HP builds.
Old 04-06-2016, 08:07 AM
hrdtail78's Avatar
hrdtail78
hrdtail78 is offline
What cam are you going to use? Use what you CCP is going to be to determine if you need releases. Not static compression.
Old 04-06-2016, 09:00 AM
Wide Open Cycles
Former Sponsor
Zippers has one as well, it's in their MM conversion kit but they will piece it out. It may even be the HPI one, not sure. I really like the HPI one if you are willing to spend the coin on it
Old 04-06-2016, 10:16 AM
hrdtail78's Avatar
hrdtail78
Doesn't the Zippers require the use of a late model IAC motor? This will require the use of a tuner that can reverse it. Thundermax or S&S pro tune.
The S&S ECM is a nice unit. It can also be fitted with O2 sensors and does some auto tuning. The other option in the Techno Research tuning software. These are the only 2 systems I will tune a MM with. I would suggest getting your tuning strategy figured out before moving on.
Quick Reply: Fuel Moto
