TECH TIP - Cyco hyd tensioner shoe install
APPLICABLE YEAR/MODELS
Any with the 2007-up version of the hydraulic cam chain tensioners.
1. Do what you need to do to remove the two hyd tensioners from the cam plate.
2. Pull the shoes from the tensioner bodies.
3. Follow these pics:
http://s471.photobucket.com/user/gtm...install?sort=9
4. Reinstall the shoes into the tensioner bodies.
5. Reinstall the tensioners onto the cam plate.
6. Do what you need to do to reinstall the cam plate and other stuff.
DO NOT forget the oil pump alignment!
from the questions your asking,it would be a good idea to take the bike in to a shop
