Twisted crank, TWICE!
Following to see what the experts have to say...
No abuse of any kind given to the engine, I even upped the idle speed so I wasn't lugging the engine. The crank was purchased new and trued and balanced by Revolution Performance. Yes it is under warranty, but who wants to tear down a new engine. Short from launching the bike on a drag strip I don't understand why these cranks can't take normal quick acceleration. It's not like I'm putting out 120+HP.
Someone other than S&S Cycle worked on the cranks before they went into your motor, putting the blame on S&S Cycle is unacceptable. Most people on the Internet have very poor reading comprehension skills and tend to make their minds up mid-sentence.
Was the cases inspected for damage after the first crank (stock?) was twisted before putting a new crank in?
Was any of the hardware (bearings, spacers, etc.) reused while putting a new crank in?
Who did all the engine work? Could they have made a mistake?
Pinion bearing fitment correct?
Timken and pinion bearing bores/races in alignment?
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
I guess somebody already misread, misunderstood, or assumed I was blaming someone. I'm looking for answers why this would happen and how to prevent it. This crank can't be welded so how can I make it bullet proof. I mentioned it was a S&S crank so people knew I didn't install a pos crank. I sent the cases to Revolution Performance and had S&S drop ship the crank. They installed the crank, after balancing and truing it, replacing all bearings.
These guys build all out bullet proof if you must and have no fear what the results may do to your body.
https://www.hdforums.com/forum/engin...flywheels.html
