Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
My question is what would be the best compromise between power longevity . I plan on headwork on any of the 3 I don't want compression over 10.5. I like to rip early in the rpms.
I have had 2 ultima 127ci but they were for bikes I threw together to make a buck. Both were hard starting (timing) both had great Tq. No exp with the 113 or 120.
I would like 120 hp 130 or higher TQ.
The higher the tq the better!
If you're planning on keeping this bike I suggest an S&S 124". If a stock one isn't good enough people like Hillside can gee it up, or get one of their builds direct.
I'd definitely talk to some builders, set your budget, your goals, and then figure what to do. I like the crate motor idea. Keeping it on the conservative side compression wise. Just seems a little safer bet, if your on the bike a lot.
Yup-
124" with .585 or .625 EZ starts with mild compression and a good tune.
If I was going to do it over again I would do the S&S 124" as it would have cost less to do. It wasn't available when I did my 117" I would look into T-Man 625 cams and about 10.5:1 compression.
