Throttle Body ?
Throttle Body ?
Hello Boyz
My question is would the Screamin' Eagle 58mm Throttle Body P/N 27713-08, and Screamin' Eagle® Pro High-Flow Injector Kit - 27796-08
be sutible for my build ? is it to large and are the injectors necessary or any other suggestion getting ready to finally install it in my 2011 SG.
Parts List
• S&S Rocker Cover Kit: 90-4110
• S&S Super Stock CNC Ported Cylinder Head Kit with 89cc Chamber Volume: 106-3240
• S&S Wrinkle Black 106″ Hot Setup Cylinder and Piston Kit: 910-0206
• S&S Roller Rocker Arms: 900-4098A
• S&S Cycle 585CE Easy Start Camshaft Kit: 106-4382
• S&S Premium Hydraulic Tappet Set with HL2T: 330-0174
• S&S Quickee Adjustable Pushrods: 106-6051
• Screamin' Eagle Billet Cam Support Plate with High Volume Oil Pump: 25282-11
• Compression = 10:1
• The bottom end is a brand new 2011 Touring Case complete with 4 3/8” Stroker Crank. The Timken Bearing upgrade done to the left side and crank has been balanced, trued and welded.
Not too big at all. Seen 62 and 66mm size Tb on hot 106 and 107 engines that have run just fine up top and down low. It's all in the tuning.
Yes I am. For his particular application a 52mm from HPI would be ideal.
FLS103
02-28-2015 04:11 PM
ruostekasa
05-12-2008 01:17 PM
