204's in bigger motor
I have 103 with se204s right now, for me the 204 in 103 is the ultimate combo. Should get a beefed up flywheel so was thinking stroker flywheel. But since the whole thing is apart anything could be done.
The 575 and other 57 types look great on the 110 dynos I looked at. Still not exactly like the 204. the 204 has flatter tq, though way less, and hp climbs to 5.8k. the 204 has a fat power band between 5k to 6k.
The extra lift of a diff cam or diff rocker arms does nothing unless you have head work done. Factory heads run out of air around 500 lift. Only of use if you are considering headwork in the future. If that's the case I wouldn't buy the SE204 cams and rocker arms. Just buy a cam that best suits your current and future circumstances.
Here's my take on things.
If you're gonna do heads get better cams. 204 cams will not take advantage of the extra air that headwork is intended to use.
If you're gonna do heads, perfect time while things are disassembled to go high comp pistons or go to 106 or 107 cylinders/pistons.
Or if you're happy with the 103 and 204 cams as is, which is a good and reliable Street combo, save your money and enjoy what you have. I've got a stock 103 with 204 cams, Supertrapp 2-1 pipe and a proper custom dyno tune and it runs well. Many people can improve their ride with a good pipe and tune
Having said that, if going from 103" to 107" I would be looking for a cam to replace the 204s; head work or not........
rocker arm change
Sorry should have said a waste for me, didn't mean in general. For me any change has to be dyno tuned by someone competent. I did recently try out a pipe change without dyno, for one day.
The work of changing them and hauling the bike to dyno, I live remote. The cost of everything. The difference was slight. I should of did it at same time as changing cams, then why not do it.
I only did intake. Not sure if that's a problem. I got trusted advise to only do that.
