Twin Cooled cylinder differences?
I have been told that Twin Cooled cylinders are different than air cooled
My 2016 Parts manuals say NOT at least in 2016
But are they different than the older 88/96 jugs other than the bore size?
I have a set of older ones I want to bore out for a 107 on my 16 Limited
Thanks
Thanks
Starting on 2012 models I started seeing cylinders with the extra material at the top machined surface where the twin cooled heads have open passageways. On the 13 models they were on every bagger I pulled down. If you attempt to use an older cylinder on a twin cooled engine you will have a massive coolant leak where there is no material to seal off the passages.
This is a pic of an older style cylinder, this one an S&S bu the same top surface, you can see where the material is not present for the water cooled gasket seal
In this pic you can see where the material is present on a twin cooled cylinder
